1.8 20v T
(In Topic #73819)
1.8 20v T
Not cheap and not an easy conversion but there is enough room. If you need some info try the PVW website there is lots on there.
Hope this helps :wink:
The ClubGti forum has some good info on this and there is even a guide to tell you which engine codes have which bits on them AND which cars they came in.
There are companies out there (Designa Dubs for one I believe) who will supply and fit the engine for about ?4500.
Not cheap!
AL.
My Build Thread
Thats a lot of money for a conversion on a MK1 if you ask me.
What about a PD diesel lump? :dontknow:
kins said
Shudder ECU's :evil: I avoid them where possible. My dads doing a TDi transplant into his camper he's having a mere. :tlc:
You reckon that would be easier? :roll: :?
You'd need to change pretty much everything then. May as well have goen 20VT as it's far easier! :roll: :?
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
Why would it be any more dificult than a 20v t conversion? Benifits of all that torque and imagine the MPG in a mk1 8) . Cheap to get performance gains through chipping. Sounds good to me :wink:
its a ncie idea as a fantasy but inreality im not sure id fancy a mk1 with that much power, they werent ever designed for it sounds a bit hairy for me
( must be an age thing)
the chassis and brakes will need some serious uprating and A cage woulde be a good idea, itd have tp be almost race spec i would have thought and itd be horrible on the road
Ive always fancied the 1.9 conversion in mine , with 256 mm disks eibach arbs and a boge kit already it would be a nice torquey point to point machine
keeps the cars character but with a bit more oomph
can see why your tempted though
"Racing is life, everything before or after is just waiting" (Steven Mcqueen)
