1.8 16v conversion wiring - help or diagrams needed
(In Topic #73653)
Many thanks
Helios Blue
are you using the idle stabilisation valve or just using the mk1 air aux valve?
its pretty easy, only about 5 wires
Was planning on using the idle stabilisation valve, can you get away without it then?
GolfPete said
Thanks for that.
Yeah, saves a bit of wiring, just use the exsting air auxilary valve from the mk1 engine therefore wiring is all there. put it in between the air pipes as the isv is situated. job done!
the rest of wiring is same as mk1 .I used auxiciilary air valve instead of isv as they are known to give problems.
I had no problems running it this way been in car 2 years ,tsr loom is a bit pricey. any probs give me shout
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
www.vwcaddy.com
As dub-ha8 said, which model?
Email me i've got a FAQ with details of the mk1 16V wiring, basically what has been said above but a bit more details and labeled images of the loom parts you need.
Dave
wiring
Have sorted most of the wiring, however i've discovered that i don't have a Idle Stabilisation CONTROL UNIT. I got the project from a mate, and he lost it. Can anyone help? My car is a 1983 Mk1 GTi, the engine came froma 1989 Mk2 Gti ( with the larger inlet manifold). I have the white connectors from the Mk2 wiring loom, but no unit to plug on the end. The car starts, and runs, but won't idle with fully closed throttle. Hopefully when i can source a Control Unit she'll purr like a little kitten!! ( i wish!)
Cheers, Jamie
http://cgi.ebay.co.uk/…ZWDVWQQrdZ1QQcmdZViewItem
Ebay,CGTI, E38, No-rice, golfgti.co.uk, any of the other VW sites, theres normally a few people breaking mk2s
I think I got one of my wires wrong in the FAQ actually, no biggie but had the oil and water temp sender wires wrong way round. Green/Black being th oil sender, Red/Ylw being water. All the guages worked perfectly so never noticed
