02j tower with 02a gearbox
peterg60 said
AaronGTI said
Some very useful information in this thread, see the polo GTI shifter what model is it from?
Is the Audi short shifter just an OEM part?
Thanks Aaron
. Audi tt short shift is a oem part I list all part numbers when the BBQ of
Super! Enjoy your BBQ!
relay 1J0 711 202P audi dealer
short shift 8N0 711 046 audi dealer
Last edit: by peterg60
Also when selecting Gearboxes which one is better? 02A or 02J also do you have to take into consideration the other 3 letter code on the gearbox or gear ratios?
Thanks Aaron
Would this shifter tower do…
http://www.ebay.co.uk/itm/VW-Volkswagon-Golf-Mk4-TDi-Genuine-5-Speed-Manual-Gearbox-02J301107C/221228802397?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D8147464165429653330%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D221228802397%26
thickfreakness said
Cheers peter. When you say bow catches, is that the cable end attachments yeh?
yes the attachments the black sqaure head with spring. That gearbox tower should be same as my 1.
peterg60 said
02j are newer than 02a . I run a 02a box from a mk3 gti cda. I used this as I had it lying about. But when I fit my diff I use a 02j box. I've seen a list with different ratio in gearbox codes I try to fit.
Aww ok understand! Super thanks for the info
http://www.youtube.com/watch?v=sheTKD03hmo
