Wheel Size
(In Topic #134806)
Wheel Size
15 inch 4x100
Front: 9.5J
Back: 10.5J
ET 33
wheels fit without to much bother or would i need spacers or to widen the wheel arches??
any advise would be great.
Danjoeper
Thanks any ways.
dan. you will have trouble getting both 9.5s and 10.5s under the arches. being that wide with an et of 33 they will need massive spacers to stop them hitting your suspension i think. then your arches will need a bit of work too because when you fit spacers, the offset is altered.
i have 15x7s on my golf and they poke a little.
they have an et of 13 so it is the equivilant of 20mm spacers on your wheels. i had to have arch work done but i have lowered mine and wanted them to be legal.
good luck with trying to get them to look right.
they will look mean as if you manage it!
on ebay but it sounds as though it will be a lot of hassle and perhaps i'd be better off looking around for a set more suited size wise.
i would wait for some narrower ones if i were you though.
you could spend loads of money tring to get them right. narrower dishes, arch work blah blah blah.
there are other wheels out there mate
