Sterio cutting out at high volume
(In Topic #149552)
the original and still the best !
Sometimes if the perminant live feed is weak, when you turn your stereo up loud and the stero draws more current if the power feed isn't strong enough your stereo will cut out.
Easiest way to test this is to run a power supply direct from your battery to test if this is the root cause.
With your ignition off you should have a perminant 12v + feed.
