Roof Sticking
(In Topic #145453)
Roof Sticking
Does anybody have any suggestions of any lubricants I can put on the joints and folds that won't do any damage to the roof please?
Thanks in advance
first oil all the hinge points.
second if still persists disconnect the struts from the frame and see if its any better. The struts can go a bit funny and not operate properly, causing the sticking.
third, check the side tension cables are okay and not caught on anything.
regards
chortle
to lock the roof in the down position you press the frame down on the drivers side first then the passenger side, you should hear it click and yep you push the release lever down to un lock the frame.
COTM Team
