Red grille surround...on the cheap!
(In Topic #118985)
So… my plan is just to paint it but i want to do it properly. I've been told that my trim surround doesn't clip out from the grille so i'm going to do it all whilst on the car.
I've been looking at these http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219298_langId_-1_categoryId_165505#dtab and wondered would that work? It's got primer and paint and laquer included.
OR would i be better off some how sectioning off the grill from the trim (newspaper?) and then getting the acid etch primer spray and some mars red aerosole spray? I'm not sure if this would get messy as i reallly don't want to mess the grill up.
Any advice/tips? :dontknow:
cheers guys!
And would you go touch up pens or acid etch and spray can?
just take your time with it get it off the car and give it a rub down with some real fine sandpaper then a real good clean and mask it up. go slow with the spraying and don't get impatient and poke it to check if its dry :wink: 2 or 3 coats and you should be laughing
Certainly makes it easier if you can remove the trim from the grille.
MY80 GTI | MY07 GTI | MY10 S3
