Polyurathane engine mounts NIGHTMARE!
Website Manager
So ….
1. Get the car on axle stands
2. Take the weight of the engine on trolley jack
3. Undo all engine mounts
4. Slowly lower troley jack untill mount is low enough to pull out wonderful Poly insert?
Should I disconnect anything else? Shold I leave any engine mounts connected?
Website Manager
Remove the front mount and take the bracket that bolts the rear mount to the car off.
Take the bolt out of the centre of the drivers mount, lower the engine, watch out for strain on the exhaust, pull out the poly inserts, raise the engine back up, make sure the rubber flaps are in place either side if the mount and put the bolt back in. Should not be any need to unbolt the mount from the block.
