My exip mesh wheel refurb thread
(In Topic #154060)
I bought some exip mesh wheels from eBay to replace my ats
classics as they were too small for daily use. Here is a pic
of what they look like at the moment:
So I got bored and started attacking them with 180 grit. Didn't want to use stripper as I don't plan on repainting between the mesh.
Getting there! I am getting a hook and loop disc for a 4.5" grinder tomorrow and some sanding pads for it. It will make the job a lot easier. And I'll fix the curbing. Only one wheel is bad, the rest have practically none. Then I'll hit them with wet and dry, 240 then 320 then 500,800,1200. I'll use soapy water. When that's done I'll use the two finer compounds. The sisal mop and coarse compound seems aggressive! When I have finished ill seal them with poorboys wax to help prevent corrosion, as clear coat won't stick to the polished surface. Oh and one more thing. The rears are et13, and this is what they look like with a 10mm spacer.
They seem to have come up nice after your efforts. I think they're a nice set of rims and will look good once finished. Good luck with them mate.
'83 formel e
I also sorted out all of the curbing. I just blended it in, as I could not fill them, cos they are staying bare. You wouldnt notice unless you got close to the wheels, and nobody would do that anyway
above sounds good though, i bet it was a lot quicker with the grinder than by hand!
'83 formel e
I made a start on the spacers too.
Decided I haven't got the patience for these kinda jobs. Getting bored, they are getting there though. I probably will just work up to 600 grit then try the mops. Problem is if I get them nicer, they'll just go dull again, cos I won't be clear coating.
Last edit: by r_chez_08
1985 Cabriolet GL
