Mk1 Rivage Cabby
(In Topic #101729)
Mk1 Rivage Cabby
Cant find it anywhere !!!
Thanks !
bens_cab said
open the bonnet where the rubber seal goes across the rain tray there should be a cut out or clear peice under that will be the chassis number
unless its had ome of those so engine smooth mods done to it.. then it'll either be moved or someone will have have lobbed it in the bin
Trying to find a chassis number on the car, if we cant then dont know if its worth fixing up ?
racer said
if no chassis number on top of the scuttle panel try for paper sticker in boot should be stuck on the bar at the back. but if not there either your knackered i am pretty sure once car issued with q plate its impossible to have it removed
That's true. Once a Q plate always a Q plate! You can't even change it for a private plate.
Q plates are for vehicles that cannot be determined to place,age and/or build. It could have been an import and not be able to identify the year it was made - This would give it a Q too I believe.
Most kit cars are Q plates and there's no stigma attached to these - It's obvious they've been built from odd parts and years but I'd say there is a stigma to normal cars on a Q. Does seriously dent their value!
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
1990 MX5 Mazda
