Mk1 Rivage Cabby
(In Topic #101729)
Mk1 Rivage Cabby
Where can i find the chassis number on my Mk1 rivage cabby ?
Cant find it anywhere !!!
Thanks !
Thanks !
open the bonnet where the rubber seal goes across the rain tray there should be a cut out or clear peice under that will be the chassis number
unless its had ome of those so engine smooth mods done to it.. then it'll either be moved or someone will have have lobbed it in the bin
should be on your V5 if you just need the number
Prob is, there is no chassis number on the V5, car is on a Q plate,
Trying to find a chassis number on the car, if we cant then dont know if its worth fixing up ?
if no chassis number on top of the scuttle panel try for paper sticker in boot should be stuck on the bar at the back. but if not there either your knackered i am pretty sure once car issued with q plate its impossible to have it removed
That's true. Once a Q plate always a Q plate! You can't even change it for a private plate.
Q plates are for vehicles that cannot be determined to place,age and/or build. It could have been an import and not be able to identify the year it was made - This would give it a Q too I believe.
Most kit cars are Q plates and there's no stigma attached to these - It's obvious they've been built from odd parts and years but I'd say there is a stigma to normal cars on a Q. Does seriously dent their value!
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
Good info here on Q plates…
http://www.plates4less…/search_Q-DVLA-prefix.asp
1990 MX5 Mazda
