LHD golf and RHD Golf mk1
(In Topic #80934)
Does anyone have links to this information?
thanks Si
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
Sorry couldn't help myself !!
GTI Campaign Helios Blue, Going back Standard
GTI Campaign Schwartz Black shouldn't have sold
GTI Mk7 Performance pack Daily drive
Polo 1.4sel Sunset Orange The Wife's
Triumph Tiger
Triumph Tiger
jacob said
the difference is that with a left hand drive you sit on the left and change gear with your right hand, With right hand drive you sit on the right and change gear with your left hand
There is always one person… it did make is laugh though……
muttley racing ftmfw
Life Member
Dash
Under dash trim
Instrument surround
Dash wiring harness
Steering column bracket
Steering column tube
Steering column lower shaft grommet
Pedal box (welded to steering column tube on RHD, spring on LHD)
Steering rack
Speedo cable
Clutch cable
Accelerator cable
Front carpet
Cross brake pedal linkage for RHD
Sun visors
:notworthy:
rebuild in progress....
dubboy said
Different parts are:
Dash
Under dash trim
Instrument surround
Dash wiring harness
Steering rack
Speedo cable
Clutch cable
Accelerator cable
Front carpet
Sun visors
That is what I'm after I knew you would know Rajan, thanks alot…
mines a lhd and the only difference i can think of is that the brake pedal in connected directly to the servo as opposed to a linkage being used,
Anyone know if there is any noticable difference in lhd brakes over rhd brakes. From what I've heard some of the weakness in rhd mk1 brakes is due to the linkage bar from the pedal to servo?
1983 1100 C
1983 1100 C
It's supposed to be a better distribution of weight too, as your body weight on the left sort of counteracts with a majority of the engines weight to the right. I still say I'm sat on the wrong side for pretty much all UK circuits though!
Kieths point on the weight distribution is valid though :dontknow: But it has me thinking what do the Japs do ?
exactley the reason i bought my left hooker, yet to find out though.
1983 1100 C
1983 1100 C
Autocavan see below used to do an uprated across the bulkhead conversion to improve the brakes .
Copied from GSF web site ………
Despite Stan West?s involvement with VW parts from very early days, there were also other companies in competition with him in the market place. Autocavan, a VW parts specialist was started by Geoff Thomas in around 1972, and by the 1980?s had expanded their operations to include several regional branches. In 2000, GSF Car Parts acquired Autocavan, and their Farnham HQ is now a GSF branch managed by long serving Autocavan VW guru Andy Pearce.
Also see this wee link !
http://www.performancevwmag.com/forum/post.asp?method=TopicQuote&TOPIC_ID=25331&FORUM_ID=8
Your suggestion to move the brake and servo to the drivers side is covered by a link here using new parts
http://www.edition38.com/forums/index.php?showtopic=40579
From my experience if you upgrade your brakes to MK2 16V spec servo and master cylinder then fit Goodrich flexey hoses to standard MK1 brakes , stopping will be come much easier
Chudd…………
1983 1100 C
1983 1100 C
Does anyone know what modifications are required to the firewall if converting from LHD to RHD?
Can the original be firewall be modified, or will a RHD one be needed to be welded in?
Life Member
