Help Wont Start when hot
(In Topic #141147)
I have a 1983 All white Cabrio only done 47k but it will not start when hot its fine when its cools down and is never a problem anyother time ?
Any one had this problem.
Thanks Stubbsy
I had this problem too, I changed the metering head, the warm up regulator but it ended up being the fuel accumulator, now I have a spare metering head and warm up regulator!
Spence
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
HI sorry for delay my lap top packed in
Thanks for your help i will be geting a new M O T friday so will look at it then.
Many thanks this will save me so much time.
Stubbsy
2nd that on my 83 gti, poor guy before me payed out hundreds on new accum and tests and i got hold of it and plopped a new non-return valve on the end of the pump and she was fine… cheapest thing to have a go at.funk-star said
non return valve in the fuel pump.
<a><img></a>
Website Manager
Stubbsy said
Well new Fuel accumalator didnt work
Did you do a system pressure test to see if it held up before you changed the accumulator ?
As the others have said if it doesn't, first change the one way valve on the end of the pump the then accumulator.
Could also be leaking injectors, simple test is to pull them out after running and put them in jars, leave for a while, there should be fuel leakage.
Could also be the fifth injector running permanently making it starting far too rich when hot and hence not starting. Again an easy check.
I would also get control pressure readings for cold and hot, might be that the hot control pressure is too high or low which will cause lean or rich hot starting, the WUR on trolls this.
How is your battery ? Sometimes it can as simple as the engine not being turned over fat enough magnifys other issues.
