Help! Letter from the DVLA
(In Topic #89049)
I need some assistance… I received a letter from the DVLA today which stated that some of the details noted on the recent MOT did not match the details recorded on my V5C document - specifically, the chassis number and paint code.
I probably shouldn't post my whole chassis number here, however, the VIN plate has the following (where * indicates a number):
WVWZZZ17ZDW606***.
My V5C document only has the following:
17DW606***
I also have a sticker attached to the inside of the boot, on the rear panel, which has the chassis number as:
wvwzzz17zDW606***
… where the lower case letters are in subscript (i.e. smaller and slightly greyed out).
In addition, my car is metallic grey, yet the V5C notes the car as being blue in colour.
The paint code noted on the sticker described above is LY7Z, which I am informed by my local VW coachworks is "Meteor Silver", which sounds about right.
Can someone please confirm whether or not the full 17 digit code shown above is the full chassis number, or whether the shorter 10 digit code is the correct number to be shown on the V5C.
Also, if anyone else happens to know what paint code is what, can you please confirm that LY7Z is indeed "Meteor Silver"?
Thanks in advance!!
Cheers,
AndyC
Currently Golf-less…
2004 Audi A6 Avant Final Edition - Standard
Nothing to worry about, The station that done the mot probably had to manually input the details for your mot and the dvla are just wanting you to verify the numbers.
Much appreciated.
AC
WHOOOPPSS
DubPartz
Life Member
The paint code is not familiar though, I thought the GX grey was Atlas Grey Metallic (LP7V) not Meteor Metallic (LY7Z) - both are Mk1 colours though.
After this point the only option is to confirm the details are correct as to what i can see or abbandon test .
Ive also had this with other motors but mainly v.w .
