HELP HELP HELP!! bad news!
(In Topic #100712)
WHAT CAN IT BE??
As i coast clutch down the noise stops faster speed higher the noise???
Almost sounds like something is spinning and catching but i dunno what i cud be. PS deffo inside the engine nothing is catching on the outside alternator vbelt cam belt etc
:dontknow:
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
forgeman said
tappets????
:dontknow:
Usually more gradual.
Have you had the cam belt cover off yet to see if it's frayed and on its way out
Tian
1988 1.8 carb Golf Clipper
I had to replace the oil pressure regulator because under stating i would loose all compression due to the tappet raising to high could be related i guess. I use to have the cam belt cover problem so it aint that i know the noise
Cam belt and tentioner have been replaced about 3 months ago
rustys_mk1 said
cam belt cover rattling i had a similar problem and this was the cause.
same as, just sorted mine
ChrisRivage said
what kinda noise was it, this is quite a loud clunky tapping, like ur banging a hammer on the side of the engine!!
Is it road speed related or engine speed related?
Could be a duff CVJ
And, higher revs the noise gets louder and quicker it can be sittting still and when i rev it the noise is faster, when the clutch is down or being towed no noise at all!
as said it sounds more like an inner CV joint on its way out, very common and sounds horendous, the noise increases with speed too when they go so that would be the first place i would check
dont do what i did and replace ther outer one only to find it was actually the inner one gone
ChrisRivage said
i think it may be a big end! i can feel it more with my hand on the sum case!![]()
Oh Sherbert mate, bad news.
Tian :cry:
not expensive job to do, but expensive to get it all stripped and out the engine
bummer if it it that
dont assume the noise is worst case just yet, noise also travels around the engine so ideally use a long screwdriver hold one end to parts of the engine other end to ear acts as sort of stethascope might help pinpoint noise.
if big end has gone it will be a definite knocking noise not rattle
