Car cover and leaving car for winter?
(In Topic #127074)
I dont plan to use my mark 1 during the winter so was after some advise.
I dont have a garage to store the car in so what would be the best way to leave the car over the winter?
Under a car cover? Any recomendations? What covers have you guys used?
Car would be left on a grass driveway, in gear and handbrake off.
Cheers,
car cover
I have a variety of covers, if you're after a cheap shower cover then you can't beat the middle of the range argos cover.
If you love your car then I'd buy a proper tailored cover. Not sure on the make if mine as it came with my merc. It's awesome and has a breath flap in the front.
One thing I must add is what ever cover you chose will kind of be pointless if you are parking it on grass. The constant dampness will kill yours car.
My scrapyard:
1959 Karmann Ghia
1978 Merc 350SL
1981 Jetta Coupe
1985 bmw e30 chrome
1990 bmw e30 V8 touring
2000 bmw e39 M5
Wife - 2005 Mini D, 1959 Beetle
1959 Karmann Ghia
1978 Merc 350SL
1981 Jetta Coupe
1985 bmw e30 chrome
2000 bmw e39 M5
SoundillusioN said
Halfords do a 3 layer breathable cover, its expensive at £50 (but only £20 more then argos rubbish) for the small one but is a perfect fit and is the only cover i have found to A) not damage the paintwok, B) keep the car dry and C) not trap moisture!… those single ply tent material rubbish or any other plastic sheet stuff you can buy is a defo no go!, water gets trapped behind them and eventually makes your car look like its entering a wet T-short competition!
Cheers for all the advice guys,
Will probally check out the one mentioned above from Halfords
I had to feather the brakes once I did get it started again, and although the cover kept the rain out (leaky passenger side), I don't think it provided any other protection, nor caused any problems.
If it's fuel injected, consider using fuel injector cleaner soon after running your car again, as I suspect one of mine clogged up after not being used for such a long time.
Life in the French Alps: <a href="Le Franco Phoney: All things French in La Clusaz, Annecy and Haute Savoie">www.lefrancophoney.com</a>
