Can i go any lower???
See pic three……..
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=61117&highlight=
My mechanic says if i drop it 40mm the wheels will just rub on the arches and inner linings
What do you think?
Its on 195/50/15 tyres, not sure of the whell size tbh
Really can't tell from pics alone (unless they were detailed close up ones of the wheel well and tyre, etc). So I'd go with your mechanic - if he says lowering another 40mm will cause rubbing, then he's probably right. Its difficult to tell anyway, since rubbing would occur when the suspension is articulated (including the steering turning), which is difficult to check when the car is standing. The way you'd tell is by looking at the tyres, if there was any doubt. Or by keeping some kind of margin for clearance, ie not lowering it too much.
Can the arches be folded on golfs?
If so you could fold the rear and maybe purchase wider arch front wings if available.
IMO alot of hassle over 40mm but a mans gotta do what a mans gotta do
Mk1 Golf GTI
2004 Mini Cooper JCW S Works
2001 Passat TDI 130
2004 Galaxy TDI 130
1998 VW Transporter TDI
rolled the rear arches on mine it was lowered 60mm frt 80mm rear looked great.got to say though the ride was a bit rough,got to know every pothole on my local roads.i won,t be going that low again 40mm is fine  :wink:
Mine is currently on it's backside running 7.5x15's going to raise it though as I don't want to notch the inner wings to clear the drive shafts, try to keep the shafts and lower arms parallel with the floor as not to put undue stress on the running gear and cv joints. Trial and error really hence why some prefer coil overs so they can adjust to suit.
<a href="http://www.golfcabrio.co.uk">New Golf Cabrio Forum NEEDS YOU</a>
<a href="url">http://www.golfcabrio.co.uk</a>
o yes  mine on 15s
IF ya that bothered go for AIR sus! Then ya can run a comfy handling height most of the time then drop it in the weeds when posing or jack her up when ya go camping - same cost as rollin etc if your not doing it urself! (circa ?1500).
BTW Poseur!!!  :lol:
lower it is the only real way to tell
mines down about 80mm now on BBS RA's
What size is your ET
The RA's have an ET of (iirc) ET 37, so my fronts are now runnig 195/45/15 and with camber set up correctly i was getting a little rub when cornering so have rolled the arches a tad - my old clipper had a 40mm drop and never rubbed and that had 195/50/15 wheels with an ET of 33..
ET45 but i know ive had to put 5mm spacers on to clear the brakes. Simply by looking at the distance between the tyres and the edge of the arches looks like they'll just sit on them.
The problem with lowering it, then raising it if it rubs, is that the MoT tester will look at the tyres and if he sees witness marks, might assume it still rubs and fail you on the MoT, even if it no serious tyre damage was done and the suspension raised again.
My car is lowered and it doesn't rub at all!  :(  but not just lowered i can just about get my hand/fingers in between car and tyre.
If you would like to tinker with what will work and what won't. This detailed wheel - tyre - offset comparison chart will give you all the info you need.
http://www.wheelsmaster.com/rt_specs.jsp
And this will help with general Clipper info on wheels and offsets
Brakes & Wheels
My tintop is quite heavily lowered on G60's (et 35) and with 12mm spacers on the back, had no problems with tyre scrubbing but I've got a little bit of stretch going on. Im sure if your prepared to do it, buying some narrower tyres would allow you to bring it down.
How much have you lowered it by Chris and how can it not rub if its that close?
