Tin top boot lock
(In Topic #214904)
Is it possible to re-ky a boot lock? I know for the door locks you remove the pins and replace so the key works. Is the boot the same?
If so how the hell do you get to the pins?
ta
Ian
Remove the lock from the boot by removing the 3 latch screws.
Then, If you push in the chrome button, it will expose a small roll pin at the other end of the lock. Knock the pin out and then the lock cylinder will pull out from the front.
After this you change the brass pins as per the door locks, then rebuild in reverse of disassembly.
They are the little things sticking out covered in grease, but you can also see them at the bottom.
sporttrucker said
do you need the key in when taking out the barrel?
I have had it go both ways, some I have fixed I did have to have the key in, and some came out easily without.
nice place to be here, i see nice comments and nice people as well, i will make it a point to come here more often to read and post comments so people and myself benefit.
Cheers!!!
Download Toy Blast 1.0
Black 1984 MK1 Golf GTI Campaign.
thanks so much, I'd been foxed by that pesky pin for a while!Smig1003 said
You can do it, I did mine recently.
Pulled the Carpet off, drilled a couple of holes, replace the carpet…. I used it alot as it was a work car, and in the middle of the night, looking for parts it was a godsend.
Eventually Put one on each side of the Parcel shelf.
It shows in detail how to remove the wafers of the door lock and the lock barrel from the boot lock
Early 77 year model Golf. 4-Door
