Rear Seat Fabric Removal
(In Topic #151647)
Step By Step Guide
Hi Everyone,
Same as the other one but jst with the rear bench!
Tools needed PH2 + PH3 Screwdriver + Thin Ended Pliers
First thing to do is put the seats on the back of the top half then flip the bottom up and undo the two PH2 screws which hold the two plastic resting brackets
IMG_6248 by azzatdi, on Flickr
IMG_6249 by azzatdi, on Flickr
Then get your hands under the edge of the fabric and push down on your foam and pull the fabric out from under all the edges to make it all loose then pull all the fabric up like a jumper
IMG_6250 by azzatdi, on Flickr
You will then find two small metal rods in the middle of the base seat simply apply some pressure on the foam unhook the rods then remove the rods out of the black sleeves and put then put them back on the seats so you dont loose them
IMG_6253 by azzatdi, on Flickr
IMG_6254 by azzatdi, on Flickr
now for the top half the hardest part of the whole removal because its alot tighter you will have to apply a fair amount of more force thats why i started with pliers but same rules apply pull the fabric away from the edges and remove again like a jumper
IMG_6255 by azzatdi, on Flickr
You will come across one problem that you have to undo one big PH3 screw each side of the seat (these can become very tight) once when you have removed both screws the top and bottom parts will come away from one another then slip the fabric off and screw them both back together
IMG_6256 by azzatdi, on Flickr
IMG_6257 by azzatdi, on Flickr
Hopes this helps many people
Make a sticky if you like
Cheers azza
Cheers azza
