Guide to stripes and decals
(In Topic #197262)
I must add though, as these cars were built by humans not robots it's just as my car left the factory in 1983 and not necessarily how every car left.
The side stripes and rear tailgate stripe were black on all cars apart from Helios Blue and Black ones when they were silver.
The Wider part of the lower stripe as you can see sits just on the crease in the bodywork, and wraps around the door and the door aperture. It is 45mm wide, there is then a gap of 15mm and the bottom stripe is 8mm.
The tailgate stripe often missed off in a restoration is 7mm wide and sits 4mm from the bottom of the hatch.
On Black and Helios cars there was also a silver stripe which sits below the waistline trim, as my car doesn't have this I can't measure, unless someone out there has one they can?
On the tailgate there is this
and boot sticker with all option codes and vin Details
In the drivers door aperture these
this alternator one is a copy as the old one wore out, but sits just as off centre as the original did.
this one is a copy, again sat where the original was.
Last edit: by RichardHall
Your savings members days of painful headaches mate and money into the bargain!
Chairman
Please add to FAQ's!!
Dano said
One of the best threads I've seen in ages.
Chairman
Two to go in up to now - the spec codes found in the boot and
Ta
Life Member
Chairman
Life Member
Dano said
Do you have record of any that you could post up Rajan? It would be most helpful.![]()
Tyre pressure - depends on year, and wheel/tyre combo obviously!
Paint code - sticker fitted to S1 on boot floor (along with quality check sticker)
Options - sticker only fitted to S2 (S1 in manuals)
Valve tool - only on 83 big blocks
Bar code - S2 only
Petrol sticker - depends on engine and year
High voltage - only seen on TCI engines
Side stripes - 2 versions one w grain, 1 w/o
There are also stickers for the seat belts, fan, servo, front panel…
Thanks too
Rich - the black GTI pick I guess has changed as it's showing the front end, not the tailgate?
Hairyarse said
Excellent, thanksRichardHall
Thanks toodubboy
I'll read it properly next time!!
Chairman
I think there should be stencilled numbers on either the rocker cover or cam belt cover of the earlier big blocks. Not sure what it relates to though. I thought it was to do with tappet clearances the motor was set to at the factory but I'm sure Rajan will put me right!
I also found this on the back of my front disc cover, its very similar to the numbers mentioned above……
Again what it relates to I have no idea!!
