GUIDE : Changing your gearbox fluid
(In Topic #97769)
On the older cars you can remove the fill plug (which is the one used to check the level) and see if fluid comes out but this will only tell you that there is over 1.5 litres present and there should be 2.0 litres. My recommendation is that every couple of years you fully drain down and refill the box as shown in this guide.
Note for the later gearboxes (post September 8th 1987) the fill hole was moved up (7mm I believe) which means it is suitable for checking fluid levels properly.
Step 1 - Jack the car up (prior to doing this loosen the wheel nuts on the front passenger side wheel). Don't forget to use axle stands.
Step 2 - Remove the nearside front wheel completely now which gives you access to the refill hole (highlighted) and the rest of the gearbox
Step 3 - I read a lot about people getting 17mm allen keys, whilst this is a feasible method of removing the drain plug, my preference is to be able to use a socket. Thankfully I already had the ideal tool for the job which is shown in this picture, it is designed for certain sump plugs and is readily available from any good motor factor. It is 17mm on one side and 14mm on the other allowing you to effectively put a 14mm socket onto the drain plug.
Step 5 - Using the tool described in step 3, fit it into the 17mm recess used for draining the transmission oil
Step 6 - One of the benefits of using a socket is that you can get a 3 foot breaker bar on in case the sump nut is seized solid like mine was!
Note: Transmission oil smells - a lot. It is one of the most pungent fluids you'll find on a car and scrap yards stink of the stuff. Wear throwaway clothes and try and avoid getting it everywhere, use a container that can hold at least 2 litres of the stuff (should you have the correct amount in your gearbox by some stroke of luck!)
Step 8 - Leave the box to drain completely, there should be virtually no oil dripping out by the time it is empty (this is a shot of mine just after removing the plug, there wasn't much oil in it at all!). Second picture shows how much I got out, this is a 5 litre container … almost empty!
For both old and 'new' boxes you COULD fill through the speedometer hole. For the post-1987 box I'd just use the fill hole shown in step 2 but because that was not possible for my car I've simply filled the whole box through the speedo (some people recommend filling using the normal fill hole then adding the final 1/2 litre through the speedo for some reason).
On all '020' Golf gear boxes 2.0 litres of fluid will be required
Step 10 - Clean up the drain plug, the threads will probably be covered in dirt from exposure to the road so give it a good scrub with some petrol and a rag to prevent any dirt from the threads entering the system
Step 15 - Use a length of hose (garden hose if you can do no better but preferably something a bit wider to prevent air getting trapped) to give yourself good access to the funnel without using contorted methods from underneath. You could do this the other way round and have the hose in the box and the funnel at the top but either way use hose and a funnel to make life easy
Step 16 - I poured a small amount of fresh transmission oil through before I put the 17mm drain plug back in so I could see how long it took to travel through the box. The answer was about 10 seconds so if using the fill hole, allow at least 15 seconds for whatever you pour in to come out.
Refit the 17mm drain plug and tighten
Step 19 - Now simply replace the speedometer drive gear and the flange then tighten the 10mm bolt
Have a quick check round for any signs of leaks, wipe away any spilt oil then fire the car up. Give it a minute checking for drips from the drain plugs then go for a test drive
1. Don't pour the gear oil into the hole that you can see next to the engine (with a rubber boot or sensor on it). This is an inspection hole so that lets you set your timing and putting fluid in here will destroy clutches, make sure you only use the fill hole shown or the speedo
2. The redline MTL can apparently sometimes help with crunching between 1st and 2nd gear
Never had it happen to me but lots of speedo drive cogs have disappeared inside the gear box when trying to be removed. Disturb at your peril.
Otherwise 10/10 !
"ENSURE YOU CAN FILL IT BEFORE YOU REMOVE THE DRAIN PLUG"
If the speedo cannot be removed for whatever reason or the filler plug cannot be accessed and undone then dont drain it or you`ll have an empty gearbox and no way of filling it :wink:
Jon`s Dad
