what switches the K Jetronic fuel pump off in a crash?
(In Topic #242514)
I need to check the existence of a fuel pump switch
this is a mk1 golf gti kjetronic 1800 cc 1983
Last edit: by golfy1
That is if you get in a front ender that breaks the Battery, or the engine dies in gear as you didn't clutch it when the crash occurred and the engine stalls or stops.
Turning the ignition off.
Its best not to crash.
If the engine has stopped and the ignition was still on, I suspect it will still be pumping fuel through the possibly accident damaged hose. I am going to have to research this more.
