what plugs into this please?
(In Topic #242542)
I'm trying to get my golf working again and have come across this plug adjacent to the clutch cable. I can't find any mating socket for it. Could somebody give me a steer please?
Mk11800 gti k-jetronic 1983
![WP_20240505_14_45_59_Pro[1].jpg WP_20240505_14_45_59_Pro[1].jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1715016952/uploads/attachments/663914f800ef7.jpg)
That is a vacuum switch that controls the gear change indicator lamp, not often working. It should go in the vacuum line that runs to the vac advance on the dizzy. If you have a full line running to the dizzy I wouldn't worry about. If you search on here for 'gear change indicator' or 'shift light' you'll probably find some info on how it should work.
Not the best picture, but hope it helps.
That's great, thanks, also there is another plug just above in my picture. Can't find a home for it either
that goes on to the multiplug ontop of the gear box for reverse lights and trigger the econometer in 5th gear onlygolfy1 said
if your box has been changed for a none 1.8GTI version it will only have a simple reverse light switch
Last edit: by Early-1800
Everyone is so helpful, I'll have a grovel on the top of the gearbox. Thank you all so much
I've checked the top of the gearbox, and there are only two vertical connectors on it, so I guess it has been changed at some time..I did hurredly check it was a five speed box !!
I find it much easier to be helpful on the forum than FB! Could be an age thing…..
Yes, I hate Facebook too
and the forum is classifield and searchable
it is a sad loss that 99% of stuff is lost somewhere on faceache these days
