Webb Carb Vacuum hose
(In Topic #222655)
Should I re route this or leave it as it is?
Also does anyone know the part number for the vacuum hose?
From what I read on the forum, I maybe wrong I could connect s t piece to the left arrow and 1 hose would go into the original airbox? What size t piece would be required.
There was a green unit on the left, which I removed as it doesn't do anything?
Last edit: by optimusdub
The lower port on the back of the weber goes to the vac choke adjuster on the side of the weber.
Ramair (ebay) do some nice silicone pipe if you need to replace it.. think i used 3mm id pipe.
Here is a vac pipe diagram i found
