VDO GAUGES SENDER
(In Topic #223011)
Hello can you give me some advice do I need a specific sender for theses gauges or are they universal many thanks
Yes, it is a Canned sender that has two posts, and it goes on the side of the head.
The above is for the oil pressure, the oil temp is a black single pin gauge that is on the oil filter flange.
I forgot to add that the dual canned sender has the 2 electrical connections to it.
They are the low pressure at Idle switch, and the Oil pressure sender.
The Blue/Yellow wire is for the oil pressure, and the
Normal one that is connected to your low oil pressure at idle sender connects to the other. usually yellow
