Vague steering
(In Topic #245275)
Free play in Steering rack
Steering rack has slight free play detected at steering wheel (strong advice)
I had noticed that the steering felt a bit vague beforehand so I checked both tie rods and they seemed solid with no movement. This is what prompted me to get it tested.
As a ‘repair as soon as possible (minor defects)’ the inspector wrote:
Track rod end ball joint dust cover damaged or deteriorated, but preventing the ingress of dirt Font (both fronts)
However, as I say he did pass it.
I double checked both sides again afterwards and I couldn’t even see the dust cover damage referred to, but I’m no expert.
Please can one of you experts please tell me what could be causing the free play?
Last edit: by zod
Re the tie rod end boots, damage can be hard to spot. I usually give them a squeeze to see if any grease escapes
I'll have another look at the tie rod end boots and give 'em squeeze as advised. I'll also see if I can find that adjustment screw for the pinion.
Briano1234, Is there an advantage to the 2 piece tie-rod?
Thanks again
No real advantage, other than potentially more precise control of steering wheel alignment, and a much easier replacement of the track rod end in future
That's obviously for genuine VW parts, so maybe you've come across aftermarket, or used ones for sale?
