Brake Vacuum Pipe Obsolete Help
I am after a replacement servo to inlet manifold vacuum pipe, one with the non return valve. The following part is available from VW Heritage, but is only for a left hand drive! Has anyone modified this for right hand drive? Other creative solutions welcome or if there are any spares available out there for right hand drive.
Brake Vacuum Pipe 191-611-931/A
https://www.heritagepartscentre.com/uk/191611931a-brake-vacuum-pipe-for-left-hand-drive.html
Mines a 1990 / Cabriolet
Last edit: by jatflex
buy a brake booster check valve, and a 2 port or "t" for a single port and make your own.  just a length of hose.  If your hard pipe is broke, then carefully cut it off your fittings and use rubber hose to connect it to the right length and bits. Use Fuel injection clamps to attach the hoses to your bits as they clamp tighter and won't leak.
Wouldn't look as snazzy but it will work.
You can get check valves and bits off of amazon, or ebay.
Thanks for the quick reply!
