Searched everywhere, but can't find nothing about this problem
So, after my presentation, here's my problem with my Mk1 1.8 Classic Edition cabby (98 ps, 1991).
Basically, my heater blower works even when the car key is in my pocket. I tried a new relay (the Load Reduction one), because this may cause this problem. No luck, nothing changed. At this point, could be something else, or it's that the previous owner messed up the electrical circuit? Any idea what else i can check? Thanks in advance
Check he back of your heater switch.
The big Black/Red wire for 12V to ground?
The Load reduction relay can power the Fan via the Headlight switch on the stalk.
it is controlled by f14,
Everything you wanted to know about the X circuit path (load reduction relay).
https://www.vwvortex.com/threads/the-x-circuit-from-the-ignition-switch.6761577/
Thanks a lot! I did another try yesterday: if i remove the relay, the heater fan just works when the igniton is on. I'll study the circuit you sent and try to check what you told me  :$  :wub:
