Engine running weird
(In Topic #244160)
Hi!
I have an issue with my 1988 caddy 1.8L
It alternates between a really low idle (to the point of it staling unless I slightly press on the throttle) and have a quite high idle.
I haven't been able to discern a pattern to when it" switches state" sometimes it can spend 30 min or more before it switches and sometimes only a couple of minutes but generally I feel it tends to idle hight most of the time.
I'm quite new to mk1s so please excuse me if I'm missing something obvious.
/TAb
/TAb
Is it the carb engine with the OE Pierburg carb?
If so the carb can give all sorts of trouble with its vac lines , mounting base and auto choke.
No, it has K-jet injection.
I think I would start by researching the WUR (warm up regulator) and the cold start / 5th injector (I think it's called).
