Clutch problems
(In Topic #243898)
'84 cabriolet with serious clutch troubles, has almost no power
Clutch slippage can be caused by the pressure plate, clutch plate, oil seepage on the plate. How many Kilometers do you have on the car / clutch as it could need to be changed.
If you haven't replaced the Linkages and bushings you may want to do that there are 2 styles 4 and 5 speed, get the right ones
Also if your motor mounts and rear transmission mounts are bad you can get a shifter bind.
Cabby-info.com has some good information on the linkage adjustments, and mount removals.
Brakes not breaks
Brake are the 3 most safety Item on the car, you don't want to make new friends by accident.
Number 1, is the Driver, and number 2 is the seat/shoulder belt.
It's not uncommon for the shifters linkages to fail, but I suspect perhaps it's just a poorly running engine which is down on power.
I would ask you to confirm you are able to change through all the gears correctly first off, and that being the case it's a question of why is the engine down on power ….
So this could be a hundred different things, likely either a fuel Supply issue or an ignition issue, we need more information
