Number 62 relay
(In Topic #243061)
Problems trying to find an alternative
My car is a 93 clipper which left the factory with a fuel injected engine.
Any help would be greatly appreciated.
As there isn't a normal 62 for me in a 90 Digifant.
Last edit: by Briano1234
62 is for CIS, not digifant. The 2 I posted above are the correct ones for Digifant.
above from www.cabby-info.com
https://www.cabby-info.com/electrical.htm
https://www.cabby-info.com/files/electrical/Relays.pdf
If the 5th digit is A then cis. If the 5th digit is B Digifant II C is Digifant I
That will tell you more.
Brads1959 said
5th digit is a Z (if I am reading it correctly)
Not the one on the rain tray but the one on the dash.
see:
https://www.cabby-info.com/vin.htm
Yall do some weird things over there, I keep forgetting that you have a different set of fuel types in all years if there isn't a dash plaque over here, then it better be on a VIN Plate otherwise it might be considered STOLEN.Brads1959 said
Nothing on the dash Brian but I think it’s all sorted now.👍
I know that in my Raintray there was the ZZZ stamping
I suspect it is part and Parcel of the wide varieties of engines and fuel tpes that y'all used as OEM as over here, it was 79 Carb, then 80 CIS through 89 and 90 started the 2 varieties of the DIgifant Digi1 for California, and Digi2 for the remainder. and IIRC the Digi1 to 2 for all was in 1991.5.
Glad you got it sorted.
I re-read Kammy's notes in the VIN link. MEA CULPA MEA CULPA MEA CULPA.
