Speedo cable stuck in transmission
(In Topic #242985)
Should I just yank it?
Get a razor blade or very fine screw driver under the metal and work it upwards. Once started use pointed nose pliers to pull it out along with the cable.
Not sure if a new cable will fix your problem sounds more like an issue with the clocks?
Jack the car up to get both wheels off the ground place on jack stands.
Place the car in gear, and rotate the wheels a bit one way, then in Reverse try the other way.
See if the gear pops out.
I have heard of this allowing the gear to work out by taking the pressure of the transmission and rotating the gear manually to allow the gear to spin a bit as you are pulling on the cable.
If the Little c-clip on the end pops off and you loose the gear internally it will usually require a rebuild, but I have heard of folks that got lucky by over filling the tranmission with oil and the gear floating up so you could grab it with a magic finger or long needle nosed pliers.
I have one too thats stuck. Tried rotating the gearbox back en forth, but no release. I'm afraid I'm going to brake the cable …
hope somebody has some other tips?
I believe you asked Mars Red LA2A?
Mars Red it is !
Mars Red it is !
