"New" car, some questions. Bulbs, fuel gauge, wires, oil
(In Topic #242802)
I just got an 87 Golf 1 Cabrio, so super excited, but I do have some concerns, and I thought I list them all in one topic, since most of them I think/hope are very minor.
Noticed fuse nr 18 was broken, and replaced that, got the horn working, but some problems still remain.
First, the green light from the dash does not blink, the indicators work and they also make the clicking sound, but the little light just does nothing.
Second, the fuel gauge worked when I was driving home but after refilling, stopped working.
The engine bay looks good from the top, the car is mostly without rust and the interior is freshly renovated, but from the bottom, I see some hoses, etc. that are "wet", I have attached a pic with 3 oily details, would like to know if that is something serious and if I should avoid driving and if could I manage to fix that stuff myself
I also attached pictures of 2 wires/plugs that don't go anywhere, From the boot I see some speaker cables, I guess it had some wires added for sound system.
Also from the boot, the rear plate number wires are supposed to just hang freely?
It has been over 10 years since I have owned an older car, so just getting back into the hobby.
Hoses are the power steering, they are about normal.
Wait for you to get a lower mount of fuel of fuel as it need to be at 3/4 to half before doing and service on the sender.
Is your water temp gauge working? Yes, then the issue is in the sending unit, no, then your issue is the 10V stabilizer in the clocks.
I have how-to links in the archive section that may help you click the link in my signature.
Oh also, the driver side mirror housing is very wobbly, glass inside is fine. The passenger side is super solid all around
You can use a 9V dc Battery to test all the circuit path from the sender to the Gauge. see my how to threads.
The mirror housings can get loose where the spring clamp works loose. Getting a good replacement is the usual fix. You can try to make it tighter by compressing and re-spiking it tighter. it is where the mirror flag body attaches to the mount post.
I just have noidea how much fuel I have and if I have forgotten my indicator in
https://www.volkswagenownersclub.com/threads/repairing-your-flaky-water-temp-gauge.32211/
Cold solder joints in your water temp gauge, and a wonky 10V stabilizer.
The 10V stabilizer powers both the fuel and water gauge, since you said both have issues the common thing between them is the 10v Stabilizer.
If the lights for the Hazard blinks (green one in the middle, and your higher fuse is good, then it is time for a new hazard switch.
Indicators blink themselves on all 4 corners, with hazard button and when turning. The green one in the middle is the problem, that is not blinking.
If you look, the bulb in the dash is K5 and it derives power from the K circuit in the fuse box from the Relay.
It could be that the flasher is broke corroded or burnt.
Or the wire out of the Fuse panel to the indicator is also broken also the switch can be broken if both F4 and F19 are gone. If f19 is blown then the turns only cause
The indicator to glow when you use either direction, as it is back feeding from f4.
As briano says, check and keep your eye on your p.a.s. oil level.
If you're keen, then spray some degreaser or engine cleaner all over the oily wet areas to clean it all up, then go for a drive. When you get back you can have another good close inspection, and you should be able to see where the leak is coming from.
Then you can fix it.
I can't tell, but the last image showing some redundant wires looks to me like they once connected to the original Pierburg carb, and hence now not needed.
Would this be a correct 10v stabilizer ?
Thanks jazzydog and briano1234 for help and ideas
now will look into drivers side mirror and if power stearing leaks, and then hopefully can go have a MOT
