Rubber bush on throttle pedal
(In Topic #241575)
When mine went south, it was a foamy type of rubber, and I went to a laboratory supply house and got a rubber stopper with a hole in it and whittled it down, I also used a fender washer on the other side so the rod went through on the left and the washer on the right as well as the clip.
To fit the hard rubber bush make sure it's warm as it softened the rubber (place it in some boiled/hot water for about 5 mins) and use some grease on the bush to help it slid in.
