Mk1 1.8 ks2 carb head leaking water near tensioner pulley
(In Topic #241533)
Water leak is coming from either just under cam pulley behind the tensioner pulley dripping onto the mounting .its a mk1 golf 1.8 carb ks2
Sent from my SM-A127F using Tapatalk
the pumps front weep hole is right behind the pulley and IIRC it points up when I had a bad pump seal it dribbled on the pulley inside and got slung around a bit. I couldn't see it until I use my UV light. So you might want to pull the pulley off of the water pump before saying it is a bad head gasket.
