Runs but doesn't rev
(In Topic #240604)
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
Most acceleration issues are either air or Fuel or
timing.
1. Does your Distributor Advance work?
When it tries to accell does it stumble.
2. Mechanically does your Throttle body Butterfly or Carb butterfly move when you open the Throttle assembly by hand?
3. Have you validated the Fuel pressures are correct?
4. Have you validated that your frame to engine ground is the same potential as your Battery to frame ground?
Do my quick test for grounds.
Briano's Quick Grounds test. | Volkswagen Owners Club Forum
Regional Host NE
Re:
Sounds like it's only running on the 5th injector mateBriano1234 said
Have you a whine from the right rear wheel arch?
timing.
Sent from my SM-G975F using Tapatalk
Petrol has a use by date and attracts water.
If you haven't removed the tank and cleaned it, put it clean fuel it will never run OK.
If crud is found inside it will be stuck in everything else.
Fuel pumps often seize after lack of use.
