Over fuelling and takes long to start
(In Topic #208403)
My car is overfishing like crazy it uses up a lot of petrol .. when I tire to start is just keeps ones swinging and after a while it starts only when it stands for a while it's 16I life mk1 golf 2004 model .please need help
My car got this problem a few week back ,it just started over fueling I've changed from a 7 to a 6 spark plug it still does it. Every month I have to change oil. The car uses to start fine but now it takes a long time ,I turn the ignition and it swings for some time and then it starts but only when it stood still for a while it never did it… I've got some weird knocking noise from my steering and when the car is jacked up and I turn the wheel it makes the knocking noise ,when I start turning the one wheel the knock comes an then the other wheel turns and my steering was 100% but now when I yank the wheel left or right the steering is out . Can anyone tell me what to to please
My car is overfishing (over fueling?)like crazy it uses up a lot of petrol .. when I tire(try?) start is just keeps ones swinging (cranking as in turning over?)and after a while it starts only when it stands for a while it's 16I life mk1 golf 2004 model .please need help..
This indicates to me that you have a flooding issue, so is this Golf
automatic or manual
1.6 Carburetored
1.6 Diesel
1.6 Fuel injected
6 or 7 plug, what is the brand and partnumber of the plug ie: NGK BP6ES
Really need more information on which type of engine you have and the fueling method carbed or injected.
Have you checked your timing, as timing is everything.
Have you looked for carbon tracking on the HV leads and cap? (with it dark, have some one try to start the car and watch for sparking fairies dancing about the hv lines from the coil to the cap to the wires and about the head.
Knocking on turns can be but not limited to.
Bad CV Joints.
worn lower ball joints
worn tie-rod ends
bad struts
Loose steering rack mounts
If you can pull out on the steering wheel your lower steering shaft bearing can be loose.
automatic or manual
1.6 Carburetored
1.6 Diesel
1.6 Fuel injected
Bad CV Joints.
worn tie-rod ends
bad struts
Oh and the car breaths ,oil coming out of the breather pipe and by oil cap
Ive checked the steering i can pul the steering wheel back and pop it back in
AT the bottom of the steering shaft there is a bearing. If that has slipped out of the way, then push it back up the shaft in to the housing. Secure it in place with a Hose clamp, and or large tie wrap.
