Golf GX Carb
(In Topic #208160)
Can anyone help me? I've got a 1983 Golf GX that has I believe a pierburg carb and a automatic choke, as this is being ridiculously unreliable I was looking to replace the set up to a manual choke system, does anyone know what carb I would need?
Webber carb is a simpler carb to work on, set up and it comes with a manual choke, it won't give you any extra performance just more induction noise. Webber carb is the most common way to change from the complicated Pierburg.
There is a few guides out there to fix/repair the Pierburg if you so wish.
Places to sell carbs,
Not 100% sure which one you need so may be worth dropping them an e-mail to make sure you get the right one.
Welcome to Webcon UK Ltd | Webcon UK Ltd
http://www.fastroadcars.co.uk/shop/index.php
They do pop up on ebay if you want a 2nd hand one then get a service kit for £20 from the places above to make sure it's all clean and working before fitting a 2nd hand unit.
'Ive bought bits from both places and both very helpful.
Its the Weber Type 34ICH that you will be needing-make sure its the right one for your engine size! (see below)
I recommend fast Road Cars too. -01495237456. their official Weber dealers and very helpful.
For my 1.3cc it cost £180.83+Vat delivered and works brilliantly.
Note the 1.5cc uses kit 15290993, 1.6cc uses kit 15290993, 1.3cc uses kit 15290992 and 1.1cc uses kit 15290991.
Hope this helps.
Marcus.
Hope this helps.
Marcus.
Golf GX Carb
Auto are different brackets for the accelerator as well so be sure to state that! Weber is the way to go!
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
https://www.vwheritage.com/shop/WC12915290993/carb-kit-weber-1457cc-golf-77-80-manual-g-box/?crumbStartPage=1&crumbStartRow=1
Found this one online before I buy it I just wanted to check this is the right one Thank you all for your help!!!
Yes it is the 1.5cc Weber kit- but note it is for a manual car-so (as pointed out) if yours is an auto? you may have to get, or fabricate, a bracket , but that shouldn't be too hard and these carb's work well.
Good luck will cure all i am sure..
Brilliant can finally get it running properly now hopefully yeah mine is a manual car so should fit straight on
Sorry, just come across this thread, you say your car is a GX Model, this would be the later 1.5 engine and requires a 36TLP / TLP34 Weber carb to replace, I assume your pierburg carb. I think the advert at VWH is misleading.
The TLP36 is obsolete. I have just fitted a new TLP34 to mine, see my project page 28. They are still for sale.
http://www.ebay.co.uk/itm/VW-GOLF-JETTA-SCIROCCO-1457cc-1979-84-WEBER-34-TLP-CARB-CARBURETTOR-MANUAL-CHOKE-/151566118074?hash=item234a0b6cba:g:CYoAAOSw8d9UxSCN
