Fuel Gauge
(In Topic #238908)
Fuel Gauge stuck
Hi all… my fuel gauge is stuck in 1 position any help on what could be the probem? Thanks in advance..
Jamie
Jamie
Year and model would be nice to know as well as where it is stuck left right middle?
Sorry… it's a 83 GTI
Remove and check the fuel gauge sender in the fuel tank has not got stuck or the float has fell off.
The fuel sender is underneath the back seats, if you remove them you will see a circular disc/plate. this houses the sender which works on a float mechanism that moves up and down with amount of fuel. It can get stuck or even fall off, or the connectors from the wires that attach can fail. Would give this a look at first.
How to remove your fuel sender Disregard all the intank pump stuff as it is for 85-93 Cabriolets.
1984.5-1993 mk1 How to change your in-tank fuel pump | Volkswagen Owners Club Forum
repairing your sending unit
Repairing your Fuel Sending Unit | Volkswagen Owners Club Forum
how-to improve cluster grounds.
Improving your Cluster Connections and ground. | Volkswagen Owners Club Forum
If your float is Holed, then drain it, and locate the hole, you can repair t with epoxy putty, after draining the insides, and cleaning the area to be repaired. You will want to use a fuel resistant epoxy putty or liquid.
Sorry I didn't reply to the messages.. all sorted thanks for help 👍🏻
