Hot start issues and fuel pump running constantly
(In Topic #207662)
car will start when cold but not once warmed up,if i turn it off and stright back on it wont fire.
when you replaced the pump did the new one come with a non-return valve or did you have to swap that from the old pump (the fitting in the end where the fuel line fits)
ideally get the fuel pressures checked, this will tell you straight away if its loosing residual pressure after switch off or not
