Tail window removal on mk1 hatchback
(In Topic #207564)
Thank you in advance
To remove the rear window, and chrome trim, you can use a remover tool, to remove the chrome trim. That is at the bottom of the trim there is a over lap, remove that and you can get the edge of the chrome and gently pull it out. If your seal is good, then I suggest that you spray some wd-40 between the seal and the frame inside and out. Carefully let it work a minute or 3.
Carefully insert a screw driver under the lip of the bottom and pry it off the steel and work your self around the window….
I DO BELIEVE THERE IS A YOU-TUBE VIDEO on how to remove it. It is similar to the rear window of a Cabriolet.
Some folks just cut the old one off at the rear, and use a new seal going back (they sell the seal with or without the chrome trim.).
