Tail window removal on mk1 hatchback
(In Topic #207564)
Hello, looking for advice on removing the rear tail window of a mk1 hatch without breaking chrome or seal? Also a way of disconnecting the heating element of it.
Thank you in advance
The rear defroster is held on with 2 insulated spad connectors, you can pry them off with a screw driver be gentle .
To remove the rear window, and chrome trim, you can use a remover tool, to remove the chrome trim. That is at the bottom of the trim there is a over lap, remove that and you can get the edge of the chrome and gently pull it out. If your seal is good, then I suggest that you spray some wd-40 between the seal and the frame inside and out. Carefully let it work a minute or 3.
Carefully insert a screw driver under the lip of the bottom and pry it off the steel and work your self around the window….
I DO BELIEVE THERE IS A YOU-TUBE VIDEO on how to remove it. It is similar to the rear window of a Cabriolet.
Some folks just cut the old one off at the rear, and use a new seal going back (they sell the seal with or without the chrome trim.).
