B Pillar seal removal/replace
(In Topic #207336)
Sorted!! Job done.. Trial & error kinda way, It's kind of how I've approached a few things on my car.. Obviously window handle, crank off, pop door card & adjusted scrapers, hey presto 4 X 10mm bolts.. Whipped them out, & had a little play with the window, got a bit of leverage.. Hardest part was getting the rubber of the seal to line up in the actual quarter itself.. Wound up the window & it gave way as such.. Popped it in connected up then replaced scrapers, sealed the rubber with a smidgen of Pu/adhesive sealant & connected back up, put the card back on, seatbelt cover, remainder of the seal & replaced kick panel. Jobs a good un - before & 3 after.
