Mk 1 golf clipper hydro clutch kit
(In Topic #224320)
Which gearbox for hydro clutch kit
Hi all. Mk1 golf clipper. The off the shelf hydraulic clutch kits. Can you use existing gearbox or need newer style gearbox ie one with a hydraulic clutch set up already installed. Any advice from those already installed. Thanks
They work with 02A and 02J gearboxes atleast. Prob with 02M also ?
But not with 020 what mk1's usually comes with.
Thanks that means need to source a box to mate with the 1.8 8v carb engine thanks
Think youll probably need the flywheel / clutch assy as well
And a cable change
