Reverse light always ON
(In Topic #223719)
I have golf 1, petrol 1.1l , 1983, And a problem with reverse lights.
Reverse lights are always on, as soon as I turn on the key.
I thought that reverse switch on gearbox are jammed or something, but it isn't. I disconnect the wires from switch and reverse lights are still on.
Also i tried to remove fuse, i'm not sure which one should be for this lights, but i find out that if i remove 18.fuse(for handbrake and chock indicator) lights are turned off.
Very strange, and i have no idea what happened here…
If someone can help and give some solution/suggestion/advice….
Thanks.
Milan
On the drive
Myvalver 89 GTi Grey mk2 16v
Since you said you remove f18 and the issue went away, I would look at the wires running from f18 to be powering the reverse lights, a DVOM or a Test Light is going to be your friend here…..
I would say it is a wiring issue.
Yes, the car is for a long time in my family.
I check fuse box today, and find out what is problem….
Apparently some electrician connected reverse light lead to contact 30. So this is the cause of my problem.
But why he did it like this… Obviously there is a loose contact in fuse box. I noticed a lot of oxidation around that contact on fuse box.
I clean it, but connection is still weak. Sometimes i have good connection, sometimes not.
I'm afraid that lose contact is in fuse box. So I'm not sure what can i do here more…
Additional question:
I noticed that my golf has rear fog lights, but there is also no function.
How i find on internet, they are powered over relay on position 7. As i don't have that relay, can someone tell what relay should go on that position?
