Mk1 20vt conversion
(In Topic #218241)
Fuel pump help
Sounds like someones done something before you anyway. There shouldn't be a pump and swirl pot in the spare wheel well. If it's working ok then use that.
There's a space next to the tank on the drivers side that can be used for mounting fuel pumps. It's where the GTI's had a fuel pump or filter mounted.
For a direct fit lift pump in the tank you'll need a GTI tank fitted as I believe they are slightly different in depth to a non GTI tank, you can then use the lift pump from a cabby GTI i think.
Ian
So I do have a spare lift pump from a g40 if you need one… find out for sure first tho.
