IGNITION FAULT
(In Topic #217881)
83 vw rabbit
I have a 83 vw rabbit that has power only starts if you push start it or mechanic pulled on some wire near ignition switch to get it to start what could it be also makes noise when icrank it like it the sound were coming fom the glow plug light. Has new alernator battery terminals were rewired . Ignition has power to turn on lights and radio but wont crank and radio turnes off wen yu turn the key all the way but wen yu take it off comes back on
Using new off the shelf cables that are 100percent clean will give you more operating voltage and current flow.
If you place the car in Neutral, Parking brake (e-brake) full on turn the ignition key to run, not start.
Take a Battery jumper cable from the Positive terminal of the battery and jump it to your starter solenoid wire if the starter doesn't start and spin, then your starter is bad.
Ignition switches go bad, and with a DVOM you can test for 12V at the starter solenoid switch when you try to start the car.
As a quick test of the Grounds you can use a battery jumper set, Jumper the Negative post to a good frame connection, use the other wire and Jumper from the Battery negative post to the Engine block.
If the car starter spins you have a grounding issue.
Read my signature about coffee, divorces and electrics.
To be Truthful the average mechanic knows very little about electrics, ohms law, or how electrical things work.
Does the Battery have a Charge.
Sounds as if your Mechanic was throwing parts at it.
which seems to be the ignition switch wire and
There is two other sides that arnt connected nor
Can i find anything else to connect it to what are they for ?
And my negative terminal is grounded to the tranny
bolt or mount idk what it is but iread grounding to
Tranny is not so good . Also if iwas to jump
Start my starter how do i do it touch the HOT with the ignition switch plug ?
