Help push rod stuck
(In Topic #217469)
stuck!!!
Help push rod stuck
Clutch? The part looks too small to be part of the clutch mechanism….
Sent from my Moto G (5) Plus using Tapatalk
If you want the PSD Boot Sticker file, it's here: Boot Sticker
The throwout bearing is about 1 1/4 inch thick, so I can't tell if you are looking at all of it or partial.
I really never have seen a Clutch push rod Bend or Drill through, but have heard of it happening to others.
After the shift finger and axle shaft is removed a magnet usually removes it.
If the TO bearing is that nasty, I would be getting a new finger as well. I usually changed the finger out with a clutch change, which you may be looking at as well then you will know that for 100K+ miles it isn't your clutch that is the issue.
May be 5 hours the first time, shoot I can Frankenstein an Automatic in 2-3hours.
Removing the gearbox is straight forward and can be done easily in an hour if you have the right tools as you need a 12 pointed star tool to undo the drive shafts from the gearbox flanges.
All you need to know about the gearbox.
Welcome to BrokeVW.com
I had one stick to the finger and when I changed the cable the arm dropped right down (plastic stop was missing) and it pulled the bearing out of the bore, then when I tried the cable it pushed it back in sideways. managed to save the box but a lot of hassle for trying to change a cable.
