Carb to injection
(In Topic #216080)
Changing from carb to injection, please help
Sorry can't help more
with the carb tank you can use a post-84 cab/rocco or g40 shape polo lifter pump and swirl pot under the car, piped to your main pump which can be oem mk1 or aftermarket inline type (basically the same thing)
alternatively some kind of facet woudl probably be able to drw the fuel out of the tank no problem, fed to a pot of some kind to keep your main pump well fed and happy. need a filter after the pump, id go for a mk2 digifant/mk3 type but plenty injection filters out there to choose from.
fuel line new rubber front to back, or maybe bag some mk2/polo plastic lines apparently they can fit well with new rubber ends
If its CE1 wiring wise I would use oem relay socket and fuse, pop a 67/80/167 relay in there and wire up your ecu trigger wire to the purple/black in pin D/13. fuel pump power goes to E/14, if you add a 2nd wire with a male spade this is OEM way to feed engien loom with pump power, say for lambda heater. OEM looms use fuel pump relay power feed from N spade for injectors, its unfused which VW thought was fine but feel free to add a fuse if you want.
I'd put ecu relay above the fusebox to give it lots of stable power, with fuse. rest of the loom depends on what sensors and configuration you want to run
or some kind of aftermarket pre-supply pump which dont mind pumping fuel up out from the top of the tank. the main pumps generally dont last long if they are asked to do this and/or dont have a swirl pot in the system to prevent starvation when cornering
the mk1 tintop gti has a swirl pot inside and main pump is connected direct to the outlet on the bottom. the trouble is original tanks will probably have lost all the rubber seals on the pot which stops them working.
the aftermarket GTI tank swirlpot design is a primitive metal cup spot welded on the bottom. some people have reported issues running them. though with EFI this may not be quite so critical as when used on kjet injection?
the OEM VW pumps and many aftermarket pumps need a little pot before the pump to keep it fed, this pot is filled by the fuel pump inside the tank. that way if you corner hard, the main pump always has fuel supply and doesnt have to work hard drawing fuel up from the tank
so you either need a lift pump-> reservoir-> main pump, same as the post-84 cab/scirocco. or find a main pump which is ok with drawing fuel directly up out of the fuel tank
I own a 92 Cabriolet that the Main Fuel Pump died 2 weeks before Christmas… (twice in seven years).
It has as OEM 2 Fuel Pumps in-tank, and External.
Both are rated the same as in Flow and pressure. The latter use 45psi (digi) where as the CIS uses 75psi.
I converted it to a single in-tank pump rated at 45 psi and the same flow rate. Along the way I stripped the sump/swirl/filter off and ran it from the tank-filter-fuel pressure regulator…. worked just fine the single pump cost 55 dollars, vs 50 for intank, and 350 for the main.
After 7 years I had the conversion pump fail, but it didn't fail for failing it failed because the screen over the intake plugged with debris. I bore-scoped the fuel tank with my digital camera inspection tool and there was no rubber from anything in my fuel system, so I suspect that the Debris was from when my son last filled it.
With converting the beastie, I did notice that if I was @ 1/3 tank, on high speed turns, the engine would starve for fuel until I returned to normal…flat driving… small price to pay for a cheaper replacement part at 1/4 it may happen on hills. I suppose I could of re-fitted a sump/swirl/filter on it so the single pump was filling it prior to the filter, but…removing the 20+ fuel hoses and such was Marvy…. I know this pump with a regulator will deliver 85psi, at the rated flow…. Just saying there are many ways to skin a canary, it all depends on how much meat you want left on the bone. :}
Whenever my 93 main pump craps out, I will be doing the same conversion to it…..
Last edit: by Briano1234
usually there will be a coolant temp sensor at least, and trigger feed from crank sensor or dizzy hall sensor. might require a throttle position sensor, inlet air temp etc etc. soem ecu have multiple options for sensors, triggers and spark output systems it all comes down to your engien and your preference.
for example on your engine the trigger would need to come from a dizzy hall sensor for an easy life, as crank sensor would require custom work. ideally you would switch the dizzy out for a dumb unit from a digifant engine, i.e. no vacuum or weights advance as those would mess with the ecu calculations I expect. you may be able to open the dizzy and strip out all the internals, not sure? the vacuum unit certainly comes off but not sure on the weights system.
spark oputput you can usually set them up to trigger the vw ignition amplifier, or you coudl repalce it for a wasted spark off say a ford, or whatever
