Warm starting
(In Topic #203282)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/23image.jpeg)
![Mr Funk in the usergroup ‘Old timer’ Mr Funk in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
very quick post as I'm at work and rushing round like a blue hooped fly.
The new golf (MK1 Lhasa Green tin top - pics and details to follow) starts on the button every time but it's a nightmare to get going when it's warm. If you sit for half hour it's normally fine.
Had a similar problem with the old cars (Mk2 Roccos) and think it was the WUR,coil/starter but will take any help at this point.
Cheers in advance.
Mr F
It's all pointing toward that but as getting as much info as I could before I started playing with things.
Mark: Yep. Been whizzing round in the Audi for the last two years, great car but no soul. Needed to scratch the itch
Think we all have been there a bit…. mine since 81…
I really need to find another Diesel, and get it back to OEM…… The Cabbies suffice, but they aren't the one I broke my teeth on…
I love the smell of Diesel in the Morning.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5918944367423747506-1.jpg)
![RichieS in the usergroup ‘Local’ RichieS in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I have a 1.8 auto cabby with a weber something - or -other carb.
Mine used to have a problem flooding - solved by fitting a replacement vapour separator bowl (though the return to tank fuel line is still blanked off)
Try starting with the go pedal pressed to the floor (or as your cranking, press the go pedal down until she hopefully catches)
More to follow over the weekend. I ended up nipping out early and getting nine parts drenk.
Whoop!
Cheers for the help
